Been going around rectifying problems left since refurbishing my house and would appreciate some advice on this issue.
In 3 bathroom/wc's and a porch we have used Bal Superflex black grout on the floor. Just days after grouting the grout started to turn powdery white. It looks like a chalky substance is rising up through the grout.
All four areas were done at separate times and the grouting was done a few days after the tiles were laid. A different tiler did the porch area. And a new bag of the grout was used for that.
In one area there was a loose tile that caused the grout around it to crack and the exposed area has the original black colour I was expecting.
The advice I have been given to date is to either use a grout pen or use a grout saw and re-grout. Ideally I would like to do the job properly and go with the second option. But I'm concerned if I don't determine the cause of the problem first, the result will be the same
We have very hard water (I know from how often I have to de-scale my coffee machine), could that be a cause? As I could use distilled water instead. Alternatively I am considering trying to scrub a layer of the top to see how deep the white discolouring penetrates (i.e. if the cracked area is indicative of the whole lot).
