Battery for Premier 48
14 May 2009
Dundee
Morning All,
What battery is recommended for the Tex Prem 48 Metal Box?
Cheers,
Will
hi depends on how many pirs bellboxes keypads expanders you have on but i normally fit 2 x 7.0ah batterys just put two sets of battery leads into the panel or you can buy a battery splitter.
As you're going down the route of 2x7Ah Batts, please do it the correct way as recommended by Texecom for the Premier.
Premier Battery Splitter
Allows connection of two 7.2Ah batteries to a single set of terminals on a Premier Series control panel. Compliant with EN 50131-6 the Premier Battery Splitter independently monitors batteries, performing presence and load tests, signalling any faults to the control panel."
Where can I buy one of these? Dont seem to be able to find it.
Cheers,
Will
personally if you've only got a standard ish system, 1x7AH would have sufficed imo!
