Seems my post got deleted regards burner box gasket causing said issues , something the RGI will surely check.
Burner assembly is fixed @ front @ back with no fixing to sides , due to the pretty thin material used they tend to distort , howling noise is usually only heard when boiler fires from cold , once warmed burner hood/assembly expands & howling goes away.................FGA confirmed this & appliance was labeled ID.
What was the reason above post was deleted? (posted again) , if contrary to the rules on here then i won't post similar issues , considering time & effort are for free...........................please advise?
Wouldn't say it was advice but more so what the problem could be , the OP already mentioned hole in flue , doesn't mean to say OP will start removing flue assembly , anyone can download service/maintenance instructions from internet...........................seems to be a very fine line between diagnosis & advising the OP how it's done.
