Any links, Mathew?However, if you're willing to spend £15-£20 per lamp then you can now buy products with equivalent light output to 50w halogen lamps.
In general tungsten lamps produce light and heat and LED plus discharge lamps (Cold cathode, florescent etc) produce mainly light.
So there is no best lamp only a best lamp for a particular job. With mood lighting often the light output is unimportant so covering the ceiling with little spot lights as in a planetarium seems to be popular. Personally I don't want to live in a planetarium.
I would never consider a planing machine, or a thicknesser, or any sort of power saw, in a woodworking shop - makes the room too noisy and dusty.In the same way as I would never consider gas in a domestic kitchen. Makes the room too hot and damp.
LED is the direct conversion of electrical energy into the light, this process saves most of its energy.
Do you have dimmer switches? If so then you then need to consider dimmable LED lamps which are quite expensive and of variable performance at the lower price range (but still more than £20 each)
Dimmable mains voltage LED lamps have additional electronics in the base which converts the varied AC (phase angle switched) into a variable current which drives the LED bright or dim. It is this electronics conversion which varies in quality considerably.
One would hope that he sorted this out by now![]()
Nor do they not produce heat.Most of the forward biased current does not contribute to usable emitted light. So an LED is not that efficient at producing light in absolute terms but is vastly more efficient than incandescent lamps etc.
Hmmm - some pretty fundamental laws of physics are at risk of being violated hereNor do they not produce heat.Most of the forward biased current does not contribute to usable emitted light. ....
