I want to install an additional single socket as a spur on a ring circuit but I am not sure exactly what type of cable I should use.
The spur is a 13amp single socket and will be wired in to a 13amp double socket on the ring circuit. The distance of cable between the sockets will be approx 2.5m (max 3m). The socket will only be used for a hair-dryer and hair straighteners.
I have some 3 core flex cable (2.5mm2) will this be okay to use for the above purpose or do I need to use three core and earth cable and if so what mm2 should I be using?
Hope this is enough info and any advice/help is greatly appreciated,
Ed
Ed
