Mortar Colour
6 Jul 2011
Hertfordshire
laying a grey brick wall in the garden and wanted to match-ish the mortar. Using standard building sand and OPC tends to result in a dark brown mortar. Can anyone advise of formula for getting a shade of Grey...would be happy with cement colour! only doing about 1.5sqm. failing that a light beige colour would be better than brown!
Any help appreciated.
Thanks for quick reply, have asked a few merchants and stores around if there is such a thing and they all looked vague! Do you know best place to pick it up?
thanks
Coloured sand is the best option but next best is to use the lightest sand you can find and tint with a colour additive.
Thanks. Only dies I can find are black red and yellow which would not appear to be the solution.......the building sands in this neck of the woods are all a deep red.....
Black dye will produce grey mortar. You just don't throw the whole tub in.
If you can source some lighter sand to mix with the red - yellow (playpit sand) or a lighter sharp sand - then mix that with the red then that will dry a shade of grey
But in your case, dye would be simplest
thanks
Isle of Wight :idea:
The standard building sand we have here is Yellow, mixed 5:1 with OPC ( Blue Circle Cement from Wickes) and that is a grey color.
If you made a more cement rich mortar (4:1 or 3:1) it would be a darker grey.
Different cements will change the color of the mortar, Mastercrete for example is a very light colour cement, so used at the same ratio will produce a much lighter mortar.
Yellow sand mixed 5:1 with OPC.
HTH.
