Suprima 50L - Won't fire-up after being off for 1 month
11 Jul 2011
Suffolk
I wonder if anyone can help me.
I've got a Suprima 50L which was Installed in 2006 and and been running perfectly until recently.
I turned the boiler off whilst I had some work done on the central heating... a new radiator fitted during our ensuite installation. (Up until I turned the boiler off it was working perfectly).
At the weekend I refilled the central heating system, added inhibitor and bled all the radiators.
I then turned the boiler on, and it begins it start up sequence and then just starts flashing red at me. I've tried pressing the reset button (holding for 10 secs as per the manual) but it doesn't seem to reset.
Have I missed a stage out after refilling the central heating system? Can't see why something that was working fine 1 month ago, is now not working when I turn it on?
TIA
Darren
Some had a flow switch IIRC. Does the pump run when you create a call for heat?
When a call is made the pump starts to make a noise... But I'm not sure if that means it running. I'm a newbie to all this so not sure what sort of sound the pump should make.
According to the manual the flashing red light indicatea a flow swith or APS switch fault.
When it says "switch" does that imply there is a physical switch I need to press?
As far as I can recall any boiler fitted in 2006 should have been condensing.
See the FAQ for details of testing the pump.
There are all sorts of possibilities for the boiler not working now.
But you can check the pump first. Most of the other aspects will need a gas registered person.
Tony
