That's one of the biggest problems with IP ratings; people quote various 'guides' to the standard, which contain material that is not actually in the standard but is somebody's opinion, even if that opinion is from an august body such as EIEMA.See page 4 of thisWhat's that from John? It isn't in IEC 60529.1) Protection of persons against access to hazardous parts inside enclosures. This is intended to cover protection of persons against accidental contact with electrically ‘live’ or otherwise hazardous mechanical parts contained within the enclosure, e.g. rotating blades, switch mechanisms etc.
Kind Regards, John.
The standard does include a definition of "hazardous mechanical part", but doesn't use the term thereafter AFAICT. The criterion for the first digit of the IP rating is simply that the relevant probe cannot penetrate any openings.
Another problem with IEC 60529 is that manufacturers glibly quote IP ratings without specifying where they apply. For example, pushbuttons are often quoted as IP65 or better, when they can only achieve that when correctly installed in an enclosure of at least IP65. I've seen downlighters and other lampholders claimed to be IP 55, when they clearly do not restrict access to live parts if the lamp is removed, and the IP rating in that case referred to the sealing between the downlighter and the ceiling. I suspect something similar is the case with this bathroom cabinet. The manufacturer should really be more specific about where the rating applies, but many don't.
