I set the alarm to home only using the key fob.
I came down this morning but forgot to switch the alarm off using the keyfob.
The alarm sounded and I tried to switch it off at the control panel but it would not switch it off.
I pressed the green unlock key and then inserted the code, several times but it did not stop the alarm.
I then got the keyfob and pressed the unlock button and it did stop the alarm.
Is is faulty?
It has been working perfectly for about two months but I have never tried to switch off an alarm set with the keyfob using the control panel before.
Is is faulty?
