Care to explain how not even knowing how a switch works is compatible with being competent and safe to do electrical installation work?
I hope I dont come across rude, but your old switch has the terminals marked Common, L1 and L2.
Your new switch is marked up Common, L1 and L2![]()
You just don't get it do you.You do like everyone else (on this thread) has done, instead of the silly childish and deliberately stupid remarks, you give the poster the information he needs to help understand what is needed and how to do it correctly.
If you continue to criticise me for wanting to see high standards of competence and safety, and continue to do so in a way which cannot be backed up with any rational argument, but is in fact motivated by some pathetic idea that we mustn't call a spade a spade, don't expect me to stop pointing out that you are a stupid, irresponsible and dangerous little ***t.But you have in numerous ways and by numerous people been told this for many years, but I suspect you will just continue to be you. If you do, don't expect me to stop the criticism.
So?The new switch appears to have L L1 and L2 where L is the Com of the old switch.
And is that going to teach him how the switch works?Please note: New switch has been turned around, or it will be upside down when you put it on the wall.
Also the red wires are in L1 (not L2) This is correct.
TURN OFF POWER. View media item 35833
Not at all.Did you fall out of the wrong side of your pram again?
And there we have it.
NO, but it's better than him trying it and seeing what happens.And is that going to teach him how the switch works?
And that's the only thing that matters - everything else is just a self-serving justification for not giving the right advice, which is to go away and learn how it works, or get an electrician.
I think that it's essential that people understand what they are doing.
You think that that position is a laughing matter.
You are a stupid, irresponsible and dangerous little ***t.
Every single time you criticise the suggestion that people should be genuinely competent, and have a genuine, solid understanding of what they are doing, you are promoting the idea that it's not necessary to be genuinely competent, and that it is OK to blindly follow instructions without knowing why.What have I ever said that was dangerious or irresponsible?
