For the renovation of a Grade II listed thatched cottage I will need eight or nine zone control valves to control central heating flow to radiators and hot water tank coils. This is a DIY renovation of the building that will be my home.
The difficulty is these need to be operated by ELV motors ( 12 volt prefered ) and with position feed back micro switches.
A fully timed and zoned bespoke controller is being designed.
Before I design and build the valve actuators I have to ask if there is an easily available unit on the market. I have looked and spoken to the major manufacturers without sucess.
Motor direction by reversal of the DC supply. Stalling at end stops is not acceptable
Micro switches ( or similar ) to indicate fully open and fully closed
Micro switches ( or similar ) to remove power to motor if it over runs limits ( with diodes to allow motor to be backed out by reversal of supply )
Alternatively valve bodies where the spindle can be turned continuously would allow for the motor to always run in the same direction from open to closed and then in the same direction from closed to open.
Valve bodies need to be standard off the shelf items It is un-likely that three port valves with mid position will be needed.
