Texecom Premier 816 & ComIP module
25 Jul 2011
Hello,
my name is Efthymios Kalyviotis and I am computer programmer. I need to be able to read the alarms from the Premier 816 panel by using a custom software. As far as I know, there are 2 ways that can be done:
1) By using the SIA Digital Comunication Standard
2) Writing java programs and uploading them to the communicator module
Unfortunately, I did not find a lot of information for both of them and I do not know from where to start.
For the 1st, I found the following paper:
http://www.mobile-download.net/tools/Assessment/dc09_20070319.pdf
and for the 2nd the following topic:
http://www.diynot.com/forums/viewtopic.php?p=1986886#1986886
Can someone help me please? I need to have source code examples to implement something like this. I am totally newbe in alarm equipments and I need someone to point me a place to read.
Thank you very much in advance.
Yours, sincerely
  • Thanks
Reactions: bko
Or get the "wintex" from Texecom.
www.texe.com
Thanks for the answer!
Actualy I have used wintex already to configure the panel. But this is not what I want. I want to be able to receive all the alarms from a custom application (eg. when a zone is triggered). Log them to a DB and when needed the user will be able to use a web browser to get the logs and all the information s/he might need. And ofcourse, I will then be able to implement other functions such as 'SMS messages', start of a recording of a video stream from a camera, custom apps to receive all data from a mobile phone, etc.
Basically I need to find out a way to communicate programmatically with the panel from my computer.
Well as you say SIA will do that. You need to set up as a reciever. SMS can be done at the panel anyway, or with another module. Outputs can run cameras.
Nothing there that needs an app for it to work.
I need to do much more complicated things than the examples I have told you. Basicaly, my main need is to somehow communicate with the panel. Either with SIA, or uploading custom Java programs to the ComIP module. Do you know of a good site that explains SIA? Can I somehow find demo source code?
Here is how the string works, should get you started.
<START> 7 characters header
panel type 3 characters panel type eg. 001 = Galaxy alarm panel
1 character space
protocol type 3 characters protocol type eg. 001 = SIA protocol
1 character space
site number 3 characters the logical site number on the transmitting PC eg. 087
1 character space
serial number 4 characters serial number used to identify transmitting PC eg. 0112
1 character space
site name 30 characters site description as programmed in transmitting PC
protocol data ? characters the actual alarm panel protocol data (a variable length string)
<END> 5 characters terminator
Well... as far as I know, the messages sent for SIA protocol from the premises equipment are of below type. Corect?
<LF><crc><0LLL>
<"id"><seq><Rrcvr><Lpref><#acct>[<pad>|...data...][x…data…]<timestamp>
<CR>
They are taken from the following publication:
Will the alarm panel initiate the connection? TCP or UDP?
Do I need to setup something else inside the panel by using Wintex, so that the panel will know where to initiate the connection?
&#917;&#965;&#952;&#965;&#956;&#951; &#956;&#960;&#959;&#961;&#969; &#957;&#945; &#963;&#964;&#949;&#953;&#955;&#969; SMS &#945;&#960;&#959; &#964;&#959;&#957; &#963;&#965;&#957;&#945;&#947;&#949;&#961;&#956;&#959; ; &#913;&#957; &#925;&#913;&#921; &#956;&#960;&#959;&#961;&#949;&#953;&#962; &#957;&#945; &#956;&#959;&#965; &#960;&#949;&#953;&#962; &#960;&#969;&#962; &#952;&#945; &#964;&#959; &#954;&#940;&#957;&#969;
English (?) translation >
Cheerful I can send SMS from the alarm? If YES you can say to me that him I will make
