I agree totally. Indeed, even if an RCD were (if it functioned correctly) the panacea that some seem to think, there would still be the possibility that it would fail to function when it should - so, like you, I would generally not omit any safety measures which would be required in the absence of an RCD simply because I knew an RCD was present.But even where an RCD is present, I would never take that as an excuse for not taking some other precaution which I would take if that RCD were not present. In other words, if I wouldn't omit some particular bonding between two pieces of equipment if the RCD were not there, I'm not going to omit it just because an RCD has been added to the design.
The matter of supplementary bonding in bathrooms which is being discussed in this thread is potentially a complicated question and my inclination would be to apply what I regarded as common sense on an individual-casis basis.
There is one bathroom situation, which I imagine is pretty common (and certainly applies to some in my house), which we haven't really discussed. If there are no exposed conductive parts in the room (and, indeed, nothing 'electrical' other than ceiling mounted light fittings and pull-switches), and if all pipes etc. are splidly connected to MPB via metal pipework, then I don't see any real point in supplementary bonding (with or without an RCD), even if someone brings the hypothetical vacuum cleaner with a frayed lead into the room, and can even imagine that some people might call it 'meddlesome'. What do you think?
Kind Regards, John.
