light switch
6 Aug 2011
Lancashire
i have just bought two light switches (MK 10amp single 2 way architrave)
i want to use them as inline switches for bedside lamps,but i am not sure how to wire them ..this is not the first time i have .have wired switches plugs /sockets.it is just that these are different.can anybody help.
Connect the LIVE (Brown or Red) from the mains into the terminal marked common
Connect the Brown or Red (that goes to the lamp) into the terminal marked L2
Sometimes the common is marked as L1. In this case
Connect the LIVE (Brown or Red) from the mains into the terminal marked L1
Connect the Brown or Red (that goes to the lamp) into the terminal marked L3
Please make sure you switch off before working on electrics.
If thats the case the switches you've bought are totally unsuitable. They are designed for fixed wiring, and to be fixed to a box buried in or on the surface a wall.
Indeed. The MK switches have no facility to clamp the cables. This means that it is possible for the live end to be pulled out of the switch :shock: With possible fatal consequences.
You won't know about it as you'll be groping around in the dark to turn the light on.
frankytee, you are going to secure the switches and the cables right?
If not, then as others have rightly said, the switches are completely inappropriate and would prove to be dangerous :shock:
Thanks everybody for your help ,a bit confused now so i think i may buy new switches.i will also consult a electrician.that is not to say i doubt you .
(just the opposite ,but you have made me think.
And the neutral and cpc goes where? :wink:
