I have extended a ring main to a new grid box with 3x20A double pole switches.
My idea of connecting are:
1. Connect the earth cable from the incoming ring main to the grids yoke.....then onto the earths of from the appliances.
2. Connect the neutral cable from the incoming ring main into a connector block in the the grid box ....then onto the Feed N on the grid switch.
3. Connect the live from the incoming ring main to a connector block in the grid box...then onto the Feed L on the grid switch.
4. Connect the L & N from the appliance to the L & N on the Load side of the grid switch.
Each of the appliances will be protected by a 13a fuse in its plug and using 2.5mm twin & earth throughout.
Is this ok or have you a better way?
Thankyou in adavance
