Hello, I currently have a baxi heat only boiler (pump in cylinder cupboard) supplying an unvented heating system and vented hot water cylinder coil. The boiler is about 20 years old now and due a change.
Was wondering should I do a straight swap for a new heat only boiler, or get a system boiler and remove the existing pump?
As I guess the new heat only boiler would need wiring into the existing pump. Whereas a system boiler would only need a live feed which is already there and could take care of any necessary pump overrun etc itself with the pump being self contained? Or am I best just leaving the pump where it is? Don't want to encourage any problems...
Anything else I should consider?
Many thanks, Chris
Many thanks, Chris
