4 staion wired intercom
Wow, that's classy stuff. And such a bargain too.
Looks like BPT and Videx have been having me trousers down.
GOOGLE >>>>
" 4 station wired intercom "
guess what come up.
If I didnt know you that remark would warrant a "thanks" but as I do.
The next pint is on me.
ROFL
Hello alumni
its to replace a 4 station one already installed (broken down ) as per link.
There is no fee to install or warranty to provide, just a simple diy solution to provide a voice link between distant rooms.
TIA
So what make is the existing?
Has ARCHER written on it . Similar in size and design to maplin link .
That'll be a Tandy one then. Is it like
this one (Ebay USA)
You could probably use the Maplin 3-station one and just parallel up two extensions to one circuit.
This one is functionally similar but significantly higher powered so you'd need to turn the volume right down or blast out your existing extensions.
Heck - I remember the tandy one from 25+ years ago
Did the job though.
this one (Ebay USA)
Hello OwainDIYer
the outer case looks different and it does have Tandy label underneath. Will try to post some images.
May try either/both ideas.
Master + 3 slaves
http://www.ebay.co.uk/itm/3-way-mas...-/290575573254?pt=UK_CCTV&hash=item43a7a76106
If you want to reuse the existing extensions you can get the 4-button master + 1 slave for a bit (but not much) less.
What sort of warranty & spares does KOCOM have ?
Thats a good replacement (like for like ) for original Archer one !
How long did it take to find ? :o
TIA
These all usually use a similar circuit of capacitor in series with the speaker, and a button shorts the capacitor (or the 2-wire line) to pass DC for call buzer.
Master + 3 slaves
Probably none.
TIA
Probably about 15 minutes of serious googlebay mojo!
