Hi, please can you help? My Hotpoint 440P Washing Machine drum will not rotate..
It fills with water no problems and it drains okay when I select the drain cycle.
So far i have tried/checked the following...
The belt is intact and inplace
I have cleared the filter
Selected several different cycles with the same issue
The lights are displayed as if a normal wash is running and the motor doesnt smell like its burnt out.
Its probably worth mentioning the drum did rotate about 5 turns when i tried it this evening and has done this occasionly when i switch off and back on again... This doesnt always happen though.
Any thoughts?
Many Thanks
Any thoughts?
Many Thanks
