Ok this is my first post, and I hope i can explain what i am trying to achieve.
I have an electricity supply which is 2 wires from a pole, the wires are exposed (about 25mm2) and are up on the outside wall , coupled to those wires are one sheathed cable neutral, one sheathed cable live, they come down the wall and through to by my consumer unit live goes through the electric suppliers fuse (100A) nuetral goes through the connectors also part of suppliers fuse, through meter to my consumer unit.
This all seems normal would you agree !!
Inside consumer unit all curcuits are wired as you would expect, however the earth terminals are connected back by way of 16mm yellow/green into the neutral at the 100A fuse...again i believe this is all as it should be and in fact was checked by the suppliers as part of a safety inspection visit.
SO...I want to put a supply to my outbuildings a subsequently my caravan.
I have a pucka terminal block at my side of the meter that is fed both live and neutral by 25mm cable...i propose to come from this...through a 60amp 30 millibar rcb then run the 25 meteres to the outbuildings...my 16mm swa cable is 2 core...i am proposing to use the wire as earth but do I need to do this?? It seems that my neutral is the earth so as long as i link any earths from circuits and caravan back into the neutral at the consumer unit it will be ok....does this seem right or wrong
Thanks for any discussion
Russell
Russell
