Moving My Consumer Unit
9 Jun 2004
Hello all ... I'm moving my consumer unit 8 meters i think i need 25mm cable and 16mm earth my consumer unit has a 100a breaker in it ... do i need a switch fused isolator in the run? if so what amp would it need to be ? the house is a 2 up 2 down small property... please help
joe :?:
you can nt move your cu yourself, since it will be live, ask your REC to put in an isolator for you.
there are lots of posts on this subject
It's not normal to have tails longer than 2 metres. I'd ask your REC about it if I were you because special protection may be required.
you could move your cu 8 metres however any tails longer than 3 metres would have to protected by a fuse to suit size of cable
zoonie that completely depends on the rec
some seem to say 2m others say 3m i belive there is one that says unlimited provided its 25mm tails
