Old radiator pipes not warming up
10 Apr 2009
Went to a property where they had a radiator removed a few years ago. The isolation valves + thermostatic valve are still on the pipes and have been shut. However the pipes leading upto the valves are cold, even when the radiators are turned on. I've followed the pipes all the way upto the ceiling where they remain cold. The other rads in the house get warm.
Its on a combi boiler (sealed system).
Does anyone have any idea why these pipes are not getting hot? Could they be cut and capped under the floorboards upstairs?
They want a new radiator fitted where the old one was removed, but i can;t figure out why the pipes are not getting warm.
There not getting warm because there is no flow.
Come on Plastic, you should of known that one. :mrgreen: :mrgreen:
Andy
Drainy i know theres no flow but i'm trying to figure out why. Homeowner says as far as she was aware, they were capped at the valves, and no pipes have been cut anywhere else.
Naz: Hi BG, got a problem with rad pipes not warming up
BG: OK. We can send someone out, it will be £700 to complete work
Naz: hold on, i you havent seen the fault yet, how can you give a quote?
BG: its fine, we're BG, we'll get work done asap
Naz: Whoa, i havent authorised the work yet!!
BG: no no, its fine the guys are already on site and works begun
Naz: But,......but
BG: you talking about my butt?
Naz: yes, no i mean come on, how did they get there so quick, i didnt even give you the address
BG: You dont need to, we know everything, we can see you, but you can;t see us.....
Naz: yeah whatever
BG: Nice boxers, like the polka dots!
Naz: :shock:
No, I`m a sh*te stirrer, i would be able to answer you question if I was :roll: :roll: :roll:
Suggest you retrain in knitting or something even less technical if u need help with this :shock:
PMSL - in another post you say that every RGI is a crook, then you ask for help on a simple problem with a rad.
I presume you are not charging the customer for your lack of ability to diaganose a fault
OH MY GOD. Really you have to ask this question? I could tell you right now what the problem is but armed with that knowledge you'd probably put me out of business. I'll bet you now, that you don't own a left handed adjustable so think of the cost of all the other tools you need.
ok I'm not spiteful it needs a powerflush. :wink:
