Looking at a quick easy way to sort out my garage floor (thick slab over DPC). Unfortunately, not sure what mix they used but it appears as if the lime is coming out of the mix creating absolutely loads of dust! I have tried sweeping it, but unfortunately, sweeping is actually creating as much dust as it is collecting!
If I rub my foot over the surface hard, I the surface is rubbing away like chalk. I had a quick go with 15 litres of stabilizing solution, unfortunately, it didnt do anything and the surface is very much the same. I am considering how I can screed off this surface to create a relatively strong dust free surface. With it being a garage, it needs to be fairly crack resistant.
I have seen 2 part resin screeds, but these look expensive, as do rubberized red or blue garage flooring finishes. I have considered a thin trowelled cement screed, but as I am looking to simply coat the top of the existing floor level, I am not too keen to lose too much in the way of height.
I was considering a 1:1 mix of cement and sand and apply it like a slip or cream on top of the PVA'd slab to a thickness of 5mm, but not sure if this will work! I want something that is cheap but will last, any suggestions? All the cement screeds I have looked up online suggest 1:3 or 1:4 and reccommend it being laid almost dry, suggesting it has to be laid to some depth (50-60mm?) for it to be effective.
Any suggestions?
Thanks in advance!
Any suggestions?
Thanks in advance!
