It doesI don't understand why RF doesn't stand for Radial Final.
..... amoungst other things
Kind Regards, John.
Me too ... that's definitely one of those 'other things' it can mean!To me it will always primarily mean radio frequency.
Hmm, would you consider a 0.75mm2 flex to be adequately protected by a 20A or 16A MCB ?Why? Most of the rest of the world gets along without them just fine.Erm...fused plugs are necessary.![]()
Obviously not in terms of current regs, but I guess that, in talking about different wiring strategies, we're implicitly consdering the possibility that the regs could be revisited, and revised.Hmm, would you consider a 0.75mm2 flex to be adequately protected by a 20A or 16A MCB ?
Against what?Hmm, would you consider a 0.75mm2 flex to be adequately protected by a 20A or 16A MCB ?
Protected against what?On the other hand, if you use cables sized appropriately to the load then they won't be protected.
And your point is?From what little I've seen of French and German installations, they end up with large breaker panels and a large volume of cabling.
And your point is?Clearly, if you don't have fused plugs, the idea of a 32A radial in 4mm2 cable becomes quite impractical. So you need a lot more radials, and effectively separate circuits wherever large loads are anticipated. If (say) 16A was the accepted protection rating, then you'd better have a lot of separate circuits into a modern kitchen !
BothAgainst what?Hmm, would you consider a 0.75mm2 flex to be adequately protected by a 20A or 16A MCB ?
Overload or fault?
Ditto - bothProtected against what?On the other hand, if you use cables sized appropriately to the load then they won't be protected.
Overload or fault?
And your point is?[/quote]From what little I've seen of French and German installations, they end up with large breaker panels and a large volume of cabling.
If you were to run a radial with 30A/32A protection, then the issues of small flexes protected by high amperage protection becomes more pronounced.And your point is?Clearly, if you don't have fused plugs, the idea of a 32A radial in 4mm2 cable becomes quite impractical. So you need a lot more radials, and effectively separate circuits wherever large loads are anticipated. If (say) 16A was the accepted protection rating, then you'd better have a lot of separate circuits into a modern kitchen !
