Ok,so I have a Drayton RTS 1 room stat set at 21 degrees on the dial.
I can feel the temperature dropping but it has to be a good 3 or 4 degrees below that before the boiler kicks back in.
Is that normal ?
Or should it be coming in as soon as the temperature drops below 21' in which case the boiler would be coming on and off a lot more than it is.
Or is it just down to the stat not being particularly sensitive ?
Is that normal ?
