Astra 07 washer pump
15 Jan 2010
Yorkshire
Just after a bit of info...my 07 astra widow washer pump has stopped working, when I mean stopped working you can hear the motor going but no water coming out of front or rear jets, reading other cars with the same problem saying it sounds as though pump blocked but I am unable to locate it and also is it a easy job.....thanks
The pumps are usually a push fit into the bottom of the washer bottle, and access is often beneath a front wheel arch.
In winter time, occasionally the pipes blow off due to frozen nozzles, but Fairy Liquid added as a window cleaner is a sure way to block the pump big time.
John :)
John :)
Cheers John, will have a look if rain eases off
