Identify this plug
bsr
5 Aug 2008
Gloucestershire
Hi Guys
Can anyone identify this plug/socket and give me a part number or suggest where I could get another matching plug? It's flush and on a lighting radial. Unlike a normal 3A plug, this one has flat blades.
I tried in the local merchants, but they said they had never seen one.
Thanks in advance
View media item 40668 View media item 40669 [/img]
Not sure they were rated to take a brown 13 amp fuse were they :?:
I thought they were 20mm fuses or maybe its the picture deceiving me
Not sure they were rated to take a brown 13 amp fuse were they :?: I thought they were 20mm fuses or maybe its the picture deceiving me
They use standard BS1362 fuses, but came/come with 2A ones fitted. I don't know what current they were rated at, but I'm sure there are some here who would argue that since a consumer could (as we've seen here!) easily change the fuse to a 13A one, it should be rated at 13A - although I rather doubt that it is! I once lived in a house (70s/80s) which had a lot of these, used for above-/under-/in-cupboard lights.
Kind Regards, John.
Used to be called a clock connector but obsolete for that purpose.
I'm surprised a brown fuse fits. I have used them for extractor fans, off a lighting circuit, and I think they come with a 2A fuse which is a bit smaller than BS1362.
Not going up in the loft to check, though.
The MK website says that they are BS1362 fuses (and that it comes with a 2A one fitted), but I can find no mention of the accessory's rating.
Kind Regards, John.
I will dig out an old mk book im sure they took 20mm fuses the same as the fused 5 amp plugtops, i vaquely recall the fuses being yellow
Think they might have been BS646 fuses
Did you know that a BS1361 fuseboard fuse picked out a toolbox in dim light will fit a fused spur, but result in a call back as the load doesn't work as the fuse is too short to make contact :lol:
Still makes a change from the other way around, all those 13A BS1362 fuses jammed in 1361 5A carriers which irratatingly seem to fit and make contact just fine :evil:
Yeah they were BS646 fuses.
I think I might have been thinking of an old fused spur which had a carrier similar to a clock plug that took BS646 fuses.
I've not seen one for years and years though.
Ha ha never done that, but I've seen plenty of 13A BS1362 fuses shoved into 5A BS1361 fuse carriers :x
