diplomat ADP8322
28 Dec 2011
West Midlands
Hello All
i have a intergrated diplomat ADP8322 dishwasher, has worked fine without issue untill yesterday, now when on any cycle the jets do not seem to spin, no water seems to reach the top two jets and the water coming out of the bottom jets is very limp, heat does not seem to be the problem, or drainage so any ideas folks?
regards
john. :(
Circulation pump gone. Very expensive part.
If the spray arms are chock a block with debris they don't rotate/spray too well. If the arms are clear then its the circulation motor as Rocks mentioned.
Could also be a weak motor capacitor but if it the circ pump is at fault as rocks suggests then put your money on a new aplliance given the make it is its really not worth spending much on
