central heating timer replacement
30 Dec 2011
Hi All
I currently have a Horstman 425 Diadem timer and it keeps loosing time this week this morning it was 3 hours behind schedule. I want to upgrade this to a digital timer, is there one that would be a straight swap? Can i pick anyone and use the existing wiring? Is there a recommended upgrade?
Many Thanks
Alex
You can use any two channel programmer (Honeywell are very good). However, the Horstmann does not use a standard back plate and the terminals are different. So there's a bit more work involved in the change.
Do you have a room thermostat? If you don't, you should consider the Honeywell Sundial RF² Pack 2. It's a two channel programmer with a wireless room thermostat.
I bought that and wired it straight in and all seems good. Thanks for the help
