- Joined
- 31 May 2007
- Messages
- 369
- Reaction score
- 0
- Country
Hello ppl
I have a vaillant ecotec 637 system boiler with a megaflow cylinder.
Today I drained the system and turned turned off and isolated the incoming mains into the house and the hot water leaving the cylinder. So that I could remove my bath taps and 2 radiators.
At the end of the day I opened up my stop cock allowing cold water back into the house I then open the hot water feed out of the cylinder and then refilled the system while the boiler was still switched off.
I then went and turned my boiler on and everything was fine.
About 2hours later I noticed the pressure on the system had dropped down to just below zero so refilled and began looking for leaks, I couldnt find any leaks so went out to the boiler and saw the boiler room filled with water and a steady stream of water leaving the boiler.
After lifting off the boiler cover it appears that above the pump is a gold cylinder looking thing that is leaking.
Does anyone know what has caused this or what it is?
Below is a link to what looks similar to mine, the gold topped cylinder is to the top right of the photo
http://www.google.co.uk/imgres?q=va...art=0&ndsp=28&ved=1t:429,r:0,s:0&tx=68&ty=104
Thank you[/url]
Thank you[/url]
