Converting outbuildings
21 Mar 2007
Durham
I have a old set of outbuildings attached to house which i plan to utilise, the main room was plastered but foun in the winter it was freezing.
two of the main outer walls are single brick with concrete roof and floor, planning on dot dab pb and skimming it all out.
build a timber frame on the two single brick outer walls and insulate inbetween also lat floor and ceiling and insulate between them, is this the way to do it?
Bets of luck.
Because you didn't say what use you were intending for the room and 'cos you're post was asking for a general yes or no, agree or not, perhaps embellished with a few reasons, and the time of the year when most regular, experienced posters were thinking more about celebrations than advising others, then you didn't receive a reply in quite the time frame that you were expecting.
But there's no need to take the hump.
Perhaps next time you'll give as much thought to your post as you expect others to give to their posts.
