Hi, I'd appreciate some advice on sorting my ceiling out.
I brought the old one down some time ago as it was damaged and unsafe as a results of a leak and then subsequent building work above.
So far I've sealed up the gaps between the floorboards and installed rockwool between the joists.
I plan next to install resilient bars at right angle to the direction of the joists, partly to help with sound proofing and partly because there's an issue with uneven joists.
After that I plant to double board it, with one layer of 12.5mm firebloc board and one layer 12.5 mm Gyproc Soundbloc board. And here's where I'm a little stuck:
Do I do one layer completely first, then do the second on top of that? The first layer I plan to be the firebloc one, does it matter if it's tapered or square edge, and do I need to tape up the joints on the first layer or only the 2nd layer, and should I board them in the same pattern or a different one. I.E. Put the soundbloc 2400x1200 at a right angle to the Firebloc 2400x1200?
Any Help much appreciated.
