Hello all,
I was hoping someone could cast an eye over a few photos I've taken, just to let me know the severity/urgency of repair work:
This shows the wood by the chimney stack. I've noticed some very very small leaks during the recent wild weather, with tiny amounts of water visible on the cement. It's trivial, but I'm wondering about the state of the wood? The stack isn't as wet as it looks!
This shows a rafter I'm a bit concerned about. You can see a split in the wood, starting bottom-right and covers most of the visible length. The angle of the split is almost directly away from the camera, i.e. 45deg looking at cross-section. Also, you can see the dark centre-line, this is an area of wood that is dry, but seems soft and brittle, as if it's rotted or something, but seems stable now.
This photo shows a small hole in the felt, there appears to be a small amount of (white) wet rot on the top surface, it doesn't seem to have affected the wood any deeper, although the colouring of the wood is darker for about a metre or so, which makes me think the wood might have been damp at some point?
This last photo shows damp wood in the corner (dead centre of photo). I probably know the cause of this, because the fascia board was partly blown off a couple of weeks ago, but should this concern me? I do intend to get it repaired, but I'm not in an urgent rush (yet).
Thanks,
Richard.
Thanks,
Richard.
