Just for my curiosity could some one please explain the major changes in the rules introduced recently.
The link seems to be BS7671:2008 not BS7671:2008 amendment 1. ?
Oh, yes.are the designated routes still applicable ?
No. Wrong way round.or can you run cables anywhere less than 50mm unprotected as long as theres a rcd?
Not quite, if you're >50mm deep and not in a wall made from/containing metallic parts then you don't need any protection for that cable, RCD or mechanical, and you don't need to worry about safe zones.Unprotected cables are ONLY allowed in 'safe zones' and if <50mm. deep must be RCD protected.
That may be so. Would that be classed as a 'safe zone'?Not quite, if you're >50mm deep and not in a wall made from/containing metallic parts then you don't need any protection for that cable, RCD or mechanical, and you don't need to worry about safe zones.Unprotected cables are ONLY allowed in 'safe zones' and if <50mm. deep must be RCD protected.
