Most powerful bathroom extractor fan?
30 Jan 2012
Northamptonshire
We have a bathroom extractor fan which is not efficient at clearing the steam from the shower. The fan is fitted in the loft. It does not have a clear manufacturers label - what it does say is
SHOWER FAN STANDARD
434454
220-240V~50Hz
15W
CE IP44
LIEFERANT / SUPPLIED BY APL
Can the forum please advise on the best most powerful bathroom extractor fan?
So it is one of the in-line fans?
ie the fan is up in the roof space?
Efficiency of the fan can be compromised by:
1. Rubbish fan
2. Fan in the wrong place (it needs to be as far away as possible from where air will come into the room)
3. Bad air inlet. If the door fits too well then the fan will be trying to create a vacuum. . If you have a 4inch fan, you need the equivalent of a 4inch opening - cut the bottom off the door.
4. Duct run too long. Those cheapo little 4inch fans can barely pump up 2 metres of duct.
Suggest you check out the above. Maybe install bigger duct. Change fan for something like this http://www.tlc-direct.co.uk/Products/SLTD350SILENT.html
900mm diameter ... 10.2 horse power (7.5kW) motor ...
:lol:
No -but seriously - you can get 12" wall fans which will do in excess of 1000m³/h, inline ones which will do even more.
Your choice is limited only by budget, as long as you don't mind replacing the ducting - if not what size is that?
One thing to check is that you've got an adequate supply of incoming air - e.g. a gap under the bathroom door - no fan will work if it's creating a vacuum in the room.
Thanks gents. The ducting size is 4". I'd like to replace the fan only.
There is quite a good gap at the bottom of the door
No, but the OP appears to have a problem clearing steam from his bathroom. One great way is to use a fan with an over-run timer.
I've just had a look in the RF Lighting book of good electrical practice, and it says a timer over-run is best for a bathroom.
Or buy a fan like the MF100 which does a proper job at the time (even has two speeds for the long soak in the shower) rather than have to rely on a timer, but.... to cover all bases here is the timer version of the fan
http://www.fans4less.co.uk/product/MF100T_MF100T
Cliverol, did you manage to get a replacement fan/timer? I have exactly the same fan that you had. It's stopped working - sounds like bearings went. I would like to replace with something that will be a straight swap on the wiring etc. thanks if you can let me know which model you put in instead.
Willmo
