The correct moisure level in a wall before replastering
30 Jan 2012
California
I recently had a mold problem in my exterior wall.
I have 80 year old interior plaster walls.
My question is on my moisture meter, what would be the correct level of moisture reading (low enough) before I go ahead and patch the plaster.
As long as you have solved the cause of the damp you don't need it to dry out. Wetter the better if you are going to render it.
Peaps shouldnt you be working
yea as you havnt worked all day you must work at night.....
and if you arent working that means you dont work full time and therefore i wouldnt employ you
Still clearing out a room, some I did around xmas. Cam is pooped, full of dust so will take some of the finish when it's done.
