An RSJ (a steel beam) can be used as a ridge beam but the two items are not one of the same.
What freddy is saying is anything can be used as a ridge beam - including a steel beam - or rsj as you are calling it. So a ridge beam might be a steel beam, or an rsj, or it might be a timber beam, or a flitch beam. or glulam beam. I'll stop there.
What's the problem. Do you need a ridge beam and not sure what to get?
Wood could be a cheaper alternative.
Not if it has to be two foot deep![]()
Steel might well be best but either way you need to have it calculated. Can't make a final decision until you know the loads.
You will not "normally" need steel for a dormer or any other part of a residential framed roof
I think FMUK is talking about Rolled Steel Joist sections that aren't classified either UB or UC, and they come in several sizes varying from 102x44x7kg/m to 254x203x82kg/m, the smallest of which is smaller than the smallest UB or UC, and the largest of which is much smaller than the largest UBs or UCs.fmck,
An rsj is not "just a small section beam." If required, rsj's can come in astonishingly large sections.
Can you explain to me how you would go about dealing with spread in a dormer roof without using a ridge beam, as maybe I've been missing something all these years. Always happy to learn something new though.You will not "normally" need steel for a dormer or any other part of a residential framed roof
"Rafters on the opposite side" i guess that you mean common rafters?
I dont understand what you are saying, and given the lack of info. ref the proposal it's difficult to comment, although:
1. all parts of a roof tie-in to make a stable frame, hence" roof framing."
2. There are numerous ways dealing with spread and point loads in any style of dormer - and none necessarily involve steel.
Joists perhaps...?Can you explain to me how you would go about dealing with spread in a dormer roof without using a ridge beam, as maybe I've been missing something all these years. Always happy to learn something new though.
