glow worm ultimate 50ff pilot lit electrode keeps sparking main burner will not light any ideas
Yes but you need to get a GSR engineer in as rectification of the fault requires replacement of/working on gas safety critical components.
I think it is.Yes but you need to get a GSR engineer in as rectification of the fault requires replacement of/working on gas safety critical components.
that is simply not true
in this order
1 - pcb fault
2 - HT lead discontinuity
3 - electrode not in pilot flame
4 - bad earthing / someone has interfered with the wiring
PCB is most likely - you do not need a gas fitter to do it for you if you can tie your own shoelaces
then you are wrongI think it is.Yes but you need to get a GSR engineer in as rectification of the fault requires replacement of/working on gas safety critical components.
What a load of misinformation. namsag has got it spot on and, and diagnosis should follow those points.in this order
1 - pcb fault
so, TW and 45yearsold - would you care to to say how many ultimate boilers you've worked on in, say, the past year?
sort of order of magnitude, rule of thumb answer would be good enough
lets be generous and include micron 100 &120 boilers
