Stub stack height
  • Thread starter Thread starter longdogs
  • Start date Start date
L
longdogs
hi
Can anyone tell me if there are any rules regarding the height of a stub stack with an AAV fitted. My current one is about 800m high but I would like to reduce it down to the minimum. It currently connects to a toilet and a hand basin and is on the ground floor.
Thanks in advance
The top of the stack should be above the spillover level of the highest appliance, IE your basin, so it's probably already as low as it can go
hi
Thanks in advance
By definition does a stub stack ever have an AAV fitted? Para 1.30 of Part H suggests not and if doesn't comply then it's not a stub stack. You still need to keep the level higher than the max basin level, but a cap is less bulky than an AAV.
hi
Thanks in advance
I've now removed the boxing and as you suggest it's only a cap - couldn't see too well until boxing was removed. It's a pain about the height though.
