Why?There should be a 230 V warning label on the die cast box.
Your house must look a treat, with all those labels on every switch, FCU, socket etc.And it might later warn someone that the bits inside are not safe to tamper with.
Thanks Mike.
It's cavity walls I have. Breeze block then brick. Normally I'd drill from the outside in. Choose a mortar seam.
Then you need a sign on the floor "Caution Hard Surface.... Falling onto this floor may result in injury "Everything has to be idiot proof these days.....
'beware contents hot'
On another note my garage floor is concrete (where the consumer unit is)...
On another note my garage floor is concrete (where the consumer unit is)...![]()
It's not a simple case of drilling through the wall. Somehow you must accommodate the cable bends.
