Pressure equalizing valve
5 Feb 2007
Liverpool
I am about to fit a steam shower and it says one of these is required t be fitted to keep guarantee on unit. I have brought the hot and cold feed up under the floor to be fitted in the rebate behing the shower enclosure. The only problem is it says these need to be accesible, which is not know possible, do these need accessing often to clean or will it be ok behind shower enclosure ?
Take the pipes just above the enclosure, fit the valve and take them back down? Is there room? Is it a combi boiler?
If you put it just above enclosure it won't be seen in normal usage, it will be accessible and you have fitted one as per the instructions. Win/win all round :)
Can you get these valves in chrome just incase you can see it and I could use chrome pipe.
not sure, i fitted one about 2 months ago in the pipework before the cabinet, under the floor.£69 from plumbcentre, so not cheap but it worked well. mine was galv steel effect, not really for show.
tried about 5 or 6 places before i could order one, not well known. the only plumber i met in the chase around who had heard of one was a lad who worked in schools and council buildings
