my word , what Pandoras box I have opened , Ok simple question , has anyone ever carried out a 6 x twin 13 A socket electrical installation on a timber frame bedroom extension ( 140 x 47 studs , slab ins' infill , 27mm thermaline plasterboard ) and if yes please could you enlighten the forum on the simplest method ? Thanks Tim from Cornwall
The answer to the first part of your question is yes.
The point that you seem to be missing or ignoring is that the electrical work you are doing requires notification to your Local Authority Building Control.
This notification may have been completed by yourself as part of the planning application, but there will be a requirement for you to present to the LABC inspectors a Building Regulation Compliance Certificate in order for them to sign off the extension.
Doing the electrical work yourself is fine except that you will be required to provide the LABC with evidence of compliance with the building regulations , Electrical certification and test results for example.
If you have the testing equipment and appropriate certificates and know what you are doing then you can complete the lot yourself.
However, based on the questions you are asking here it appears that you do not know the difference between the Building Regulations and BS7671 nor have the general knowledge to comply.
Furthermore, no self respecting electrician (at least those who are registered with a competent persons scheme) can lawfully come in at the end and sign the Electrical Installation Certificate to say he designed, installed and tested the installation.
So you must ask him, not us, how he wants the cables to be run and the especially the cable sizes, given the insulation issues.
Pandoras box no, commonsense yes.
