A SL8 G3 is an Optima, c. 2003
Looking at the manual there is a set of 9 connectors directly to the left of fuse F5.
Looking at them left to right they are >
Speaker
Speaker
Strobe +
Strobe -
T = -Ve tamper return
A = -Ve supply (0)
D = +Ve supply (12v)
B = -Ve Sounder trigger
Set
Well there ya go then, what's the problem?
Used to be done that way as the norm years ago, go for it, I'd be very surprised if you had a problem.if i link the -ve strobe to -ve bell would that not overload the circuit an possibly cause the fuse to blow or even worse ??
SL8 optima panel switched negative dont forget optimas/accentas strobe will flash until the reset button is pressed !!!!!!
