New stop cock
19 Nov 2008
Dorset
I'm just doing my Kitchen up, so it's stripped out, and the electrician has done his first fix.
The stop cock is shared and outside on the path. I want to put one in the Kitchen. The existing pipework has a variety of styles and sizes, I think 3/4" (O.D. 3/4") and 1" (O.D. 1")Galavanised with 15mm in places.
First, is it 3/4" and 1"?
I want to re-new all the pipes in the Kitchen. Is it ok to unscrew the first bit of pipework where I can grip the pipe, and fit a stop cock. Reduce it to 15mm and run it to the Kitchen taps plus up stairs to the Bathroom?
Should I use Copper or plastic?
Cheers, Camerart
3/4" and 1" OD galv steel will probably be 1/2" and 3/4" respecrively.
Most of the 'experts' on here will tell you copper is best.
