A
ALEC1
Sorry Alec, I don't like same manufacturer solutions especially Viessmann, and I don't like your suggestions even more. Back up has always been the first consideration, and if I was spending £10, £20, or even £30k on a top of the range system I would demand it.
This is a highly emotive sales pitch that really plays on the the insecurities of our clients..
Installed as design engineers suggest (i.e. a package from one manufacturer) these systems are reliable. Agile in one post says that two break downs in 7 years is about average for condensing boilers, but if you install as designed you can expect less than this.
Last week I went to an 7 year old Atag install looked after by BG with cylinder sensor, out door sensor and the proprietary control (i.e. as it would be installed in Holland by the design engineers presumably!). All I had to do was repressurise the expansion vessel.. That is a pretty common experience, but only when proprietary controls are used and you you follow boiler manufacturers schematics...
