Multimeters
20 Nov 2011
London
Hi all
I have a question about multimeters. I have picked out a really good multimeter with brilliant spec however the batteries it requires is two 1.5V AAA batteries as opposed to other, slightly more expensive but lower spec multimeters which take one 9V battery.These however are out of my price range.
I was wondering, will the the fact that the multimeter requires only 3V battery power make any difference?
Thanks in advance
More information on the meter you're looking at and what you're using it for would be helpful.
Don't. They're crap and the specs aren't even that good.
How much were you going to pay for that thing?
The price was £34.99 from amazon. Could you possible recomend a better one for under £40.00?
i had one of those it went up in smoke got a fluke now
Unfortunately Flukes are usually too expensive for normal users (non-trade or professional engineers.) However there are plenty of suitable alternatives, if you shop around carefully.
Probably anything at the same sort of price but where they've not frittered away some of the money providing useless fripperies like capacitance, frequency, temperature and transistor and diode testing.
Have a look at Maplins electronics UT30B multimeter, very good spec for only £14.99, certainly adequate for usual tests.
Wotan
I can tell you've never done electronics before.
  1. I have.
  2. If I wanted to measure capacitance I would not try and do it with a shoddy £35 multimeter.
  3. If I wanted to measure frequency I would not try and do it with a shoddy £35 multimeter.
  4. If I wanted to measure temperature I would not try and do it with a shoddy £35 multimeter.
  5. If I wanted to test transistors and diodes I would not try and do it with a shoddy £35 multimeter.
IMO ones like these:
on the grounds, as I said, that at a given price point the fewer the functions the meter has included the better made are likely to be the ones it does offer.
Personally I would advise against an auto-ranging meter, in the same way I'd advise anyone who'd never done off-road driving against getting a vehicle with hill descent control - you need to learn how to use the tool properly and to develop the habit of thinking about what you are doing, not the habit of thinking you can just connect the probes and the meter will sort it out.
Amprobe are part of Fluke, Di-Log are, AFAIK, an OK make, and the Sealey looks like the same thing. Rapid Electronics are an educational supplier, so they might have a good idea of what's well made and what isn't.
Plan B: Start looking on eBay for used Fluke/Robin/Megger etc multimeter.
Plan C: It will mean spending more than your budget, but you could put in a nominal bid now to kill the B-I-N, and then try sniping at the end for a bargain:
http://www.ebay.co.uk/itm/Unitest-t..._Measurement_Equipment_ET&hash=item3a73520e81
If you want a meter for domestic electrics that will do everything you need, including all sorts of things you don't yet realise you need.
  1. I have.
  1. Depending on what you're doing it for, a decent £40 meter works fine.
    [*] If I wanted to measure frequency I would not try and do it with a shoddy £35 multimeter.
    [*] If I wanted to measure temperature I would not try and do it with a shoddy £35 multimeter.
    [*] If I wanted to test transistors and diodes I would not try and do it with a shoddy £35 multimeter.
Transistors yes, diodes, depending on what you're doing it for, a decent £40 meter works fine.
