D
drkdeath5000
Hi all,
I've been investigating my phone line connection and sockets / boxes as broadband is especially slow and constantly disconnecting. Theres also static on the phone. I believe its down to bad wiring and the age of it all. Looking at it id say the boxes are from around 1970 / 1980, the wiring alone is that bad im suprised its working at all and then theres the added corrosion.
So considering the above i've set out to install my own NTE5 master and some new CAT5E wire. The new nte5 master arrived yesterday and i fitted it to the old wire, still awaiting the new CAT5E cable to arrive.
So currently i have the old wire connected to A and B on the new NTe5 master socket. Broadband and phone is working fine, same speed but less disconnects. However, the NTE5 also comes with some sort of a faceplate which currently isnt connected up.
Reading up online i'm under the impression that there should be two cables coming to the new NTE5. One of which should be the drop cable from outside that connects to A and B. And another cable which connects to the faceplate. I only have the one cable which comes from outside so i'm not sure how to go about this now.
Am i simply missing something here or am i actually missing a cable ?
To explain further i have attached photos of the new and old equipment aswell as a diagram showing my proposed connections. Just bear in mind i may have some of the terminology wrong so the boxes may be named incorrectly etc.
Drop box from outside
Drop box internal wiring
Old junction box (now removed)
Old master socket (now replaced with NTE5)
New NTE5 with A and B connected (faceplate not connected)
Diagram
Any help or advice would be greatly appreciated and if anyone needs any further info please ask.
Diagram
