Hi, I am replacing the disgusting 2 in 1 shaver socket/light fitting the developers fitted in my newly built home (built April 2011) with a heated/illuminated mirror and separate shaver socket. Obviously, since this goes beyond a like for like swap and will introduce new cabling in a bathroom, I will have to get an electrician in to connect things up but if I can I’d like to run any additional cables required myself to keep costs down.
Anyway I have the following questions:
1) The Existing shaver socket/light fitting is feed by a spur from the lighting circuit, is it OK to feed both the mirror (250W max) and shaver socket off this one spur or do I need to feed a second cable down from the lighting circuit in the loft above? I’d like to avoid running the extra cable if possible because it will mean making lots of holes in the wall and then plastering over it.
2) Assuming I can use just the one cable to feed both mirror and shaver socket, I intend to fit a junction box in the stud wall behind the mirror and use this to split the output. The shaver socket will be mounted immediately to the side of the mirror thus I will have a short horizontal run of cable. I know that horizontal runs are a big no-no when plastered into a wall but wondered if a short run between two adjacent items in a stud wall was ok? After all cables are generally free to meander around in a stud wall anyway. If the answer is no then I guess I will have to run a new cable down from the loft anyway.
3) Are all shaver sockets IP44 rated and therefore ok for zone 2? The information on the usual DIY shed’s websites is pretty poor.
4) Does a shaver socket need its own isolation switch? I can’t say I have ever seen an isolator for a shaver socket but times change.
Many Thanks, James
Many Thanks, James
