Hi all, i am in the same sitatuon as new2 however my ceiling rose is located downstairs in the living room and i cant get easy access to the wiring as its under floor boards in the main bedroom. My solution therfore sounds like i have to go down the choc block route. Can anyone confirm that these are just the plastic 15a terminal blocks? Do i need to enclose this in the "choc box" that you can buy or like the wiki advises, wrap up in insulation tape? To me that sounds a bit strange. The hole in the ceiling where the 3 wires come out is not big enough for me to use a choc box, so i will have to use the terminal blocks alone. Do i need to enclose these somehow or can i simply place them once all wired up into the new light fittings metal rose as its got a little space?
Many thanks!
Many thanks!
