The inside of the container is still eventually going to end up the same temperature as the outside no matter how much insulation you stick in the walls. All additional insulation will do is slow the process down. And reduce the amount of moist air in the container as it's using up space I suppose. Ventilation is the only way to go, will stop it getting mouldy too.
