Hi again folks, firstly - thanks for the help I received when I last posted about setting up our house alarm. Everything running smoothly in that department.
My new problem is - We feed birds in our garden which is lined with bushes and unfortunately under a certain small tree we have a problem with cats occasionally hiding and catching birds. This evening's victim was a collared dove. I have just ordered for the purpose of scaring the cats off -
1 x Lyntec soundbomb Voltage:12vdc Current:85ma
1 x ESP Quest Alarm PIR Voltage:12vdc Current:15Ma
I have a 12v 1.2 Ah battery with which to run stand alone cat scaring equipment, but would also be willing to buy a power supply unit as we can then wire it through the wall and switch it off at the plug. We will be switching off at night in case it scares off the foxes (which we also feed).
My questions are -
1 - Do I need to set up resistors to protect the PIR and soundbomb, and which resistors do I need?
2 - Will the system automatically stop and reset or do I need more components?
I will waterproof everything with a plastic bag for the soundbomb and battery/power supply and bath sealant for the PIR.
Any help to get me moving in the right direction would be greatly appreciated,
Cheers
Pit
My questions are -
Cheers
Pit
